2011 Charger camshaft timing help
Hi!
First of all, I did find several similar posts, but still confused! :D
I'm attempting to tune a 2011 Dodge Charger 5.7L that has had a Comp Cams Phaser Limiter Kit #5761 installed as well as a Comp Cams 201-303-17 camshaft.
Using HP Tuners, I disabled the MDS I am having problems figuring out how to properly set up the numbers to properly control the cam timing. I did try no adjustment as well as a couple different settings and the car barely starts, runs like crap and dies unless I force it to keep running with the throttle, plus numerous codes set.
Not sure if it is gonna be something that will tune out or if the shop that installed the cam made a boo boo?
Any advice would be appreciated. (And I am not apposed to paying someone for some help!)
