Can TCM from an 8HP70 be used on an 8HP95, seems the ratios of both transmissions are identical, the 95 is just beefier. Can it be done or needs to TCM from the 8hp95?
It can...
However, 8HP70 was designed by OEM to handle up to 700Nm of torque. In case you engine is capable of 850Nm (for example), tranny will likely limit it to 700Nm
Thanks.
DodgeBoy
YouTube: https://www.youtube.com/@dodgeboy2785
Would that be editable though?
Unfortunately not with HP Tuners...
