3 Attachment(s)
Unknown factor effecting ignition despite spark source remaining unchanged
Car is a 2018 F150 2.7L.
I have this odd issue with something adding in to the ignition output that I can't locate. Spark source remains borderline the entire run, but you'll see timing picks up these frequent 2 degree drops. They are not showing up in the logging as corrections and I've picked up every advance related parameter I can.
At first I thought it was due to the throttle closure (working on WGDC, separate issue) but even when throttle is fully open during the run the drops are there.
Another minor oddity, I did a similar log using an external OBDII tool and the standard timing advance cyl1 parameter, sample speed around 6hz, and did not see the timing drops in its trace.
Bonus points if someone can tell me where the "popcorn" torque max source comes from. :)
Attachment 87650Attachment 87651Attachment 87652
