Im working on a 2010 Camaro 2ss ls3. it has cats gutted. im trying to get the code p0420 and p0430 to go away. Its just not working for me i have done this on my 5.3 c10 swap no problem but this one is pissing me off.any advice?
You left the SES box checked.
And even if you remove the SES box it will still show up as a permanent code that doesn't just vanish when you disable it. It'll stop the engine light from coming on but will still show up when you pull the codes. Maybe after a long time it'll go away but maybe not.
You also didn't disable the catalyst test in the exhaust tab. Plus you left cat over temp protection enabled, disable that.
Yeah, uncheck the SES box if you don't want the engine light to come on.
Cat over temp is in the engine tab > fuel > temp control. COT is the table.
