Axle Ratio Change Not Working
I confirmed yesterday on my 2006 300C SRT8 with a swapped EGS53 (came stock with a EGS52) the gear ratio change isn't working. I followed the procedure, then went back to check it took, showed my last inputs, re input everything again, hit the EGSINIT, went for a ride and threw all the normal incorrect gear ratio codes and wouldn't shift out of 3rd.
Went back in with my DS handheld, programmed the new gear ratio, worked perfectly.
Not sure what to send support to try to figure this out. Thinking pre-all changes, then after HP Tuner change, then after DS change read out?
