More Newbie questions (might as well get them out of the way)
I am using TrackAddict solely for autocross on a Nexus 6P Google phone, in case it matters.
1. AFter tapping "Set with GPA or Map" to establish a start line or finish line, the next screen shows a satellite view and the instruction says "Use current location" which when tapped is followed by a screen with "Set Point Here" and speaks to being as close to the track surface as possible. During the pre-run course walk I can stand right on the track itself in line with the timing boxes - is that what is asked for? Once pressed, the program reverts to the "Use current location" satellite view screen. I assume we don't press that again, but exit to the "edit track" main screen?
2. The Start Line, Sector Split, and Finish Line set up sections have "Tolerance" choices. Did I miss the discussion of those in the Online documentation? Default appears to be "Standard".
3. What does "heading" do in setting the start or finish lines or sectors?
4. Is it possible to have the voice announce the segment time, similar to announcing the lap time?
I apologize for all the newbie questions and thanks in advance for the help! My goal is to get TrackAddict set up properly and then add OBD and lastly my 360fly camera once I have everything else sorted.
Bill
