I believe I have this correct, but I'd like some of the more experienced here to verify I've got it right. I have an AEM 30-0300 wideband, I'm taking the brown analog sensor ground from the wideband to the red connector pin 41 EGR ground on the 0411 PCM, and the white analog 0-5 volt from the wideband to the red connector pin 7 EGR +5 volt signal on the 0411 PCM. Is this right?
Attachment 90996
Thanks ahead of time!
