TPS correction from datalogs
I have used the app on some track sessions and found that my TPS logged position is off, it reads about 9% when closed and maxes to 90% when open
Searching the forums I found this is due the fact sensor TPS works, as it reads around 0.5v when closed and 4.5 or so when open, thus no correlating
question is, is there any easy fix/workaround for when you load this data into racerender? because the TPS gauge is really awkward and didnt found an easy way to fix the values.
Thanks a lot for the help in advance.
