Originally Posted by
RoninDusette
What tables do you have in the turbocharger section of torque mgmt? Boost pressure may not be what you need to be setting per se. If it's anything like the gen v boosted ones I have worked on, you will want to set your torque to where you want it, and whatever boost pressure it takes to get there is what it is. But the boost limiters if I can remember off my head (the hard limiters) would be like, max boost pressure and boost ratio max and pressure delta or something like that. , as well as your torque settings. Like, I use max boost pressure set to 280kpa, and my pressure ratio or whatever its called to 2.80, which keeps my boost limited to 26-28 psi (depending on torque request). From what I gather, everything is converted into a torque request. How? I dunno. I may be talking out of my ass, but that has been my experience.
