AEM Wideband Voltage Drop On HPT Pro
Sorry for the long post. My HP Tuners connection appears to be messing up my wideband outputs.
I have 2 AEM inline wideband controllers (30-0310).
Hooked into HP Tuners Pro.
Brown Wire On Pin 5 and White Wire On Pin 1 for Left bank and Pin 6 and 2 For Right Bank.
Pin 5 and 6 also grounded to the body
Aeroforce Interceptor Scan Gauge single wires ALSO hooked into pins 1 and 2 so the widebands will show up on the Interceptor.
I had planned on using either HPT or Aeroforce but not both at the same time. They both power on via OBD port, so only would plug one in as needed.
The Aeroforce displays 14.1 or 14.0 for both widebands if they are connected to HP Tuners... but no higher. The widebands voltage output actually drops to 2.95 or so, car off. If you connect HPT to a laptop (still no OBD plugged in) the AFR display goes back to normal. 17.8 with car off... almost 5 volts i think. If you unplug the green connector, it reads normal also.
I double checked resistance to ground and the power supply. Everything looked ok. Why would an unpowered, yet connected HP Tuners lower the voltage output of my widebands? Is there a better way to connect everything?
It appears to be logging right in HPT for AFR. My lambda setting must not have been right, but I think thats just a setting that needs adjusted.
I'm sure I'm doing something wrong. I've never had problems in the past with AEM, but just didn't want more than 1 gauge for 2 widebands. Car is a 2012 CTS-V Wagon if it matters.
Edit - I found a couple threads with similar issues, but no answers.
https://forum.hptuners.com/showthrea...-not-hooked-up
https://forum.hptuners.com/showthrea...HPtuners-cable
