3V 2010 F150 using "Dashpot" while idling stopped.
I'm starting a separate thread on this specific issue to see if anyone else has seen it; I didn't want to bury it in another longer thread. It was my understanding that Dashpot settings where only used while moving and off the throttle but logging a '10 F150 with the 3V it doesn't appear thats correct. I start the truck, it goes into RPM controlled idle after it stabilizes, when I hit the throttle then let off it goes to "Pre-Position" (which I assume is Dashpot Pre-Position) then "Dashpot" control. The problem is the "Dashpot" setting doesn't appear able to keep the throttle open; blade position drops as low as 1.7% once it idle goes into "Dashpot" control and the motor dies...what gives?
