2 Attachment(s)
Not really DI but a 19' 2500 6.0l Odd issue with Maggy Charger
This is very odd as the truck runs great on the dyno or during a pull in one gear on the road. This owner did not want to wait for TCM unlock or trans tuning so I have some work around stuff for that but it does the same thing with the Maggy tune also.
Once in a while and no always after a WOT shift it will spark knock and miss like crazy. Commanded AFR stays put and I do not see any odd TM kicking in. You can see the MAP reading go straight through the roof when it does too. There is no way a little 1900 could make the boost it says but with a violent miss I suppose so?
