3 Attachment(s)
As it is from your recommendations
Quote:
Originally Posted by
blindsquirrel
Make sure to check the gear ratios to see which trans it is for any files you use like that, if you try to apply what works on a built 80E to your stock 70E you will have a very bad day. A +$5000 70E might could deal with TM cut down to almost nothing, but... why? I just don't understand the obsession with 'firm shifts'. You know what feels even better than firm shifts? A transmission that isn't broken, that's what.
Ok, this is the tune I am currently on, I copied adjustments from yours, switched back ALL the "DO NOT MESS WITH" items and ran the tune. It was blinding rich, like -18..... LOL
I made a tweak to this, then to that, got it reap close, then tweaked it by tiny increments between MAF and Spark and I have ended up with this.
I still have a spot of KR (I logged burst aslo) in a couple places, depending on gear I'm in, but it's less than 2?, still only lasts about 1000rpm I was going to try the MAF first, if that seems to work I'll go that direction to get rid of it, if not, I'll play with spark in the areas, but I guess I am wondering also, while 0 is best, how bad is a 1000 rpm blip of say a max of 1.7?? I will add it no longer seems shift related, as it doesn't follow a shift like it used to.
Given my comment, MAF then Spark? You have any suggestions before I mess it all up again? ..... LOL
Current tune; Attachment 99978
These logs are long, they were driving around doing errands, then a trip to Kokomo on the first day, it was warmer too, like 80 or 81 w/50% humidity.
First day log; Attachment 99979
Second day log; Attachment 99980
The cruising speeds were similar to first day (warmer) log, but it was way more rich and my KR over 2? in some of the same "throttle on, easing in, climbing and shifting" but it lasted longer so that was why the question "where would you start" since it obviously needs to have less KR and a little less fuel in most areas "outside the 40 thru 65 to 70 cruising ranges" which all stay around 0 to -1.
Love to here your thoughts!
