1 Attachment(s)
HELP: 2000 LS1 Mafless Tune wont start or idle (for long)
OK I give up. I have read so many posts and double checked so many things I don't know what to do but to ask.
I pulled a complete 2000 LS1 engine, trans loom and wiring out of a donor car for my 58 Chev Truck build. I wired it all up factory with no mods on open headers and i ran. If you are interested there is a youtube video here
After I confirmed that the engine ran at least I pulled the engine down, gave it a once over and threw some new goodies at it as follows;
- TEA stage 2 - 5.3L 862 truck heads
- TFS stage 3 cam (Duration: 228/230, Lift: 585/585, 112lsa)
- Trunion upgrade
- Edlebrock super victor intake
- 4150 throttle body
- 1 7/8" to 3" headers
Anyway - with the factory tune it did run (kind of). Here is Another Youtube Video before covids and during that time I decided to make the required mafless changes.
So i have done a number of changes to the tune (all from this site) and I got it to the stage it kind of wants to start (but not really).
- Changed "Engine Diag / DTCs P0101, 102, 103" from "no mil light" to "mil first error"
- Unticked "Engine Diag / DTCs P0101, 102, 103"
- Changed "Engine Diag / Airflow / Maf fail hi freq" from "11.25" to "0hz"
- Copy the "high octane table" to "low octane table" in "Engine / Spark / Advance"
The bit that I am lost on is how to change ?Engine / Airflow / General / Main VE? to use the Secondary VE Table for 97-00 (not primary ve). Is this an automatic thing or something I need to switch somewhere? So far I have copied the primary table to the secondary table (where I could as the secondary has less values - refer image).
Attachment 102814
Question 1
Can you add lines into the secondary table or is it not required.
Question 2
Could my issue be fueling as I still have the stock LS1 injectors in the rail (it ran before i made any mafless changes)
I just want to get it to start and idle so I can then get it on a trailer and to the tuners.
Any help appreciated
Q
