Hello,
I'm looking for a vcm file for a Magnusson or Weistec supercharged C63 from 2009 M156.
Thanks, best regards!
Hello,
You are going to have to make your own ;)
I know, it's easyer for me to tune when I can see what for tabels are to edit.
Of course it is easier to copy/modify someone else's work. That's not what real tuners do though. They use their experience and knowledge in an applicable manner to produce a solid product.
It's my own car, I do this with HP tuners and in general with HP tuners for the very first time. I am a motorcycle tuner (engine build till to dyno tune) and I can say that motorcycle ecu?s are much easyer to edit and handle as a vcm tune for a car. I don't want to steal any ones work or ideas, I only can't figure out what actual maps are to edit for best results.
My problem is: The gas mixture leans down in half load before the boost commes, the other things in the tune I have made is perfect and works good.
Change lambda full load and then target lambda base for fueling.
Make sure you are pulling a bunch of timing from the stock file or you are asking for trouble!
These two tabels dont help by this problem.
Anyway I already found out what it actual was.
Thanks for nothing.
