Which one do I use ?
Which one of the license selection do I need to use my credits to ? It says 2 different choices ? Gm e92 or gm_c304 for the controller types ? I have the new hp tuner that just came out ? Thanks
Edit I chose the first one with my vin because the other is the body control module. so I applied the credits and it shows that it accepted. I resyncd and when I go to make a change it still says I am not licensed to make these changes... any ideas ??
Re-Read the file but only select the PCM/TCM or just the PCM.
If you have the option to read the FPCM or body module, uncheck the box.
