High Altitude Tuning For Haze
Hey folks. 04.5 with 5" exhaust, aftermarket turbo, no cat, CAI, BD lift pump. I live up at about 9600ft. I am trying to tune out some of my Exergy BMS 50hp injector hazing. I know these injectors are sort of notorious for haze, however they are clear as can be at sea level. I feel like if they are that good at sea level and warmer temps, there should be a way to get them similar with some tuning at altitude. I have upped my timing in the idle ranges, tried an extremely slight pulse reduction, tried open and closed air box theory. They aren't problematic, as the truck runs and starts perfect, balance rates are all within spec, injectors test great, no oil in fuel, new head gasket not leaking anything anywhere. I have about 7000 miles or so on the injectors.
