i can scan the transmission ZF trans. will not pick up the ecm. I can't even start a ticket now to get support started on the software engineering side. why are you doing this to people.. where is the customer support?
I've had that issue on other TDI's. If they support the trans tuning, it won't let you scan generic obd parameters for the engine. On the manual cars you can do it.
I've meant to contact support about it, but never got around to it.
They give the option for an access code I believe they call it. I wonder if it is the same Audi code for security-based parameters in the ecm. I even manually selected the supposed supported style ecms.
its a shame. I havent been able to find a place to submit tickets into on the main site
