2 Attachment(s)
GT500 Weird idle issue when clutch depressed
I had this GT500 motor come in with a bad motor. Low holes. Rebuilt the motor and went to tune it when i found a weird issue i've never seen before. Its a 2013 gt500 with a kenne bell, return fuel system, stage 3 cams, DW 200lb injectors, etc. When i built my base tune got it running and dialing it in, i noticed when pressing the clutch the spark would drop negative and start surging really badly. I've done a few builds like this and have had a good base tune for these things. I played with a bunch of things to try to figure it out and nothing. Took a look at the tune that it came in on and they had this sucker running -12 degrees at idle. So i threw those settings into it and sure enough press the clutch and nothing changes. No way this can be right. If i try to run any regular idle timing in this thing, the second the clutch is pressed the timing drops to min and of course throttle body tries to react for it and surges bad. I've tried playing with min spark and such and if i raise it to let say 10 degrees, it'll go straight to 10 degrees and stay there when clutch is pressed. I looked at all source values and nothing changed with clutch pressed. Any ideas on this?
Stock tune is one it came in with. My base tune is all over the place now from playing with it.Attachment 93930Attachment 93931
