VVT Questions - VCP PDA table and mechanical limits of advance/retard?
I have been searching for about a week without luck or mixed info, so here are my questions:
What is VCP PDA spark? Says for when the swirl valve is closed? I can't find any more information on this table.
What is the limit in the L83 advance and retard? HPT has a huge range, but then I read you could not actually advance the cam any more than 0 deg. I was going to try to taper to more retard towards higher RPM WOT. Stock is 8 deg, was going to try to work up to 12 deg and test it out.
Bonus, does anyone have the cam specs of the 5.3L/L83? I was trying to see what the ground in advance was, I found 8.5 deg but not sure if that is for the 5.3L.
Thanks.
