I hooked the pin 1 to the yellow, then pin 5 to the same ground wire that the LC-2 connects uses. Then setup the scanner with input 1 and transform using built in lc-2.
Logworks shows 14.7
Scanner shows 15.1
I thought as long as the grounds were shared it would avoid this issue...what could I be missing?
