1 Attachment(s)
Fuel pressure reading dropping out
I keep seeing an odd issue in VCM scanner with reading the low pressure fuel sensor (SAE) on C7 corvette. This has occurred in the last couple versions of the scanner, including 4.4.4 and the current beta. MPVI2 using USB cable.
When reading the sensor, sometimes I will get a flatline response at 57.9psi with zero variations in pressure. If i disconnect and reconnect several times, then suddenly I will get a valid reading again and it will fluctuate as expected. Also, if I do a longer data record, you can actually watch the sensor readings work, then flatline for a bit, then work again.
Ive delete a bunch of channels thinking there was congestion on the lines and changed polling rate, both without resolve. Deleted the PID and re added. Didnt help either. Graph attached. Ideas? Thank you!
Attachment 91934
