Can I have 800 bucks too ?:pray:
No shit, lol. Luckily, the shop I work for is a GMPP installer, so I can get that done for free/cheap, lol. Hopefully parts at cost too hehehehehehe.
Otherwise, its wait til HPT unlocks the dang thing.
fuel pressure vs load ftw!
DALs are used for throttle control so if you set them super high in the lower desired torque columns you can get full throttle and full boost at 30% throttle. Does not help with response time when going from lift throttle to WOT instantly only helps a lot when you roll it on like when you pass someone on the hwy.
I figured as much but that is all we have for now for the ETC. A lot of people dont realize the DALs control throttle position with respect to desired torque which is partly computed by pedal position so in a way it relates pedal position and actual throttle opening percentage. I too wish we could shorten the 1 second delay in throttle response when stabbing it quickly. I miss cable operated throttles and their instant response.
We need something to control the throttle blade when we boost higher than 22 psi. Seems like we are still having on and off problems with that.
:hi:
http://www.hptuners.com/forum/showthread.php?t=26697
No offense intended, but develop or lose the LNF business like a set of keys. If thats the end game, then so be it. It annoys me I have more control over my grandpas Silverado than I do my turbo Ecotec.
what we need....
Fuel Control... prssure and injector pulse timing
Wastegate actuator control
What would be cool....
Boost control in with launch control (varying RPM)
ive added the fuel table, map scale, fan table requests to the main suggestion thread...as chris has stated he wont be able to work on these until 2010 as we are backed up through the new year with new gm defs.
Ok, thats great. What else could we be looking at as well?
How about the rest of the boost tables, or wastegate duty cycle (might be all we need), and some OS tricks would be nice. Whatever can let the engine take more air load.
Uh yeah, and then it starts...os mods are unlikely. I mean seriously you guys are asking for specific tables, wouldn't you like to get those before os mods :shrug: I don't understand the thinking with this...this is not a feature request thread, this was a "what tables do we need thread" if it gets too far off of track from that I won't hesitate to close it.
So, we are looking to be stuck at 22.5psi of boost forever.
Awesome.
So what am i missing? Your doing fuel, which is perfect. Map scaling, which will help alot (and I thought was an OS tweak, my bad!), and is also perfect. But I know there are other tables we need besides this. So, what table are we missing that lets the engine go past 255kpa? And why are we getting shut down by the throttle blade?
So, here... since I don't know the names of the tables, we need whatever tables will fix:
- The throttle blade closing at boost higher than 22.5psi and higher RPM (overboost apparently isn't cutting it). Not sure if MAP scaling is all we need.
- Whatever will let the motor produce more air load when it is commanded (thus higher boost).
- Something to fix the darned throttle delay (not sure if its possible through a tune, just tossing ideas out).
- Whatever will let us run the Stage kit sensors, without the calibration.
Those, along with the fuel tables, wastegate tables, fan control, would be nice.
I was not intending to take the thread off path with the OS thing, I thought that the MAP sensor scaling was an OS tweak.
And, just so we are on the right page, MAP scaling will let us run a 3 bar, right? Thats all I want.
Seriously I have no idea, I'm not an engineer, I don't reverse engineer code, I take table requests & forward them to the engineer in charge of that particular pcm.Quote:
Maybe it is, maybe you are hardcoded to that kpa, I have no clue, Chris may have already answered that on the forum :shrug: If its hardcoded its likely something we won't touch.Quote:
Not necessarily, LS2's have had map scaling but that doesn't mean switching to 3 bar is easy, in fact they are hardcoded to 255kpa.Quote:
Adding a map scalar IMO more than likely would just open another can of worms leading to dozens of more requests...its a snowball effect.
In reality in the 2 months this thread has been up has really enlightened us on what needs to be added or what is wanted to be added at least so its served its purpose for now. I'll consider reopening at a later time if necessary. As recently stated though we won't be able to look into more stuff until sometime in 2010, first quarter maybe.
-Bill
