2 Attachment(s)
Incorrect values with Haltech Elite data file
Hi,
I am currently in the learning phase of the Race Render software. I did a data overlay and maybe i might be doing something wrong. My data is not displaying as it should. I am using data from a Haltech Elite 1500 ECU. For example the boost pressure does not display correctly when a add it. Also the speed does not display correct. I hope i am doing something wrong which could be fixed. I have attached a picture at which the moment i was playing the video and some of the data can be seen in the picture which for example the actual values should be:
Speed: 112MPH
Boost:27psi (Round gauge in right corner)
Air Temp: 40 degrees centigrade (white number in right corner)
The only things that are correct are the rpm, shiftlight and indicated gear.
I hope i am doing something wrong which could be corrected.
Regards,
