twin turbo 5.3 dbw termX tandum with stock pcm going wot i get limp mode
truck is a 07 Tahoe with stock long block and a mild cam. had twin 61mm turbos, Holley hi rise, stock tb and otherwise stock. it has the stock pcm powering all the bcms and stock computer stuff. the terminator is controlling the motor and trans. wondering if i have a issue with the tb? terminator? or is it something in the stock pcm i overlooked. looking for help.
So, I didn't install the terminator x unfortunately. now i wish i had... traded out some work with a friend. all is well when i drive it. if i roll into the throttle it is fine going wot. if i go wot without delay from no throttle it will pull for a portion of first just long enough for it to start making boost and it falls on its face. throttle sticks at 20% and i have a dead petal. if i reset the stock pcm and crank it up again its fine. no clue why its doing this as stock pcm to my knowledge cant even see the tsp. i logged with hp and its tps value is at 100 all the time. i just now disabled p1516 and haven't had time to flash or see if that's it yet.
