Lc-2 Wideband hooked up threw A/C wiring and MPVI2
So after lots of searching I found enough info to get my lc-2 reading on hp tuners basically I hooked the yellow analog wire from the Lc-2 to my high pressure A/c sensor wire the orange and black wire. Here is a write up on the wiring. file:///C:/Users/Owner/Downloads/MPVI%20and%20MPVI2%20WIdeband%20options.pdf
And here is a video on how to set up the sensor to read on Hp tuners. I had to make some adjustments to my calculations to get it reading the same as the logworks gauge but it works.
https://www.youtube.com/watch?v=Ru_2M2uGSKs
Here is the numbers needed to do the user entered math:
Analog Output #1 (Yellow) is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR; Analog Output #2 (Brown) 1.1 volt = 14 AFR and .1 volt = 15 AFR.
https://www.innovatemotorsports.com/products/lc2.php
