5 Attachment(s)
1954 Ford w/ 2005 Supercharged Roush Engine Tune Help.
Hello,
I am working on a project with a guy. I will give a little background first. The car is a 1954 Ford 2dr wagon with a 2005 Ford Mustang Roush Supercharged engine and matching automatic trans. We used Ron Francis wiring kit. The car also has a return style fuel system and is only using front 02 sensors.
1. I am having an issue with no throttle response when the car is running. When the car is off I am able to use the pedal to work the throttle body, but when the car is running the throttle does not work.
I do have codes P2104 AND P2111 both for the TAC.
I even disabled the IPC monitor and I am under the impression that when this is disable it stops the quizzer from controlling the throttle.
I have a new pcm flashed to the vin of the Mustang GT before it went to roush. I found some tunes on here from a supercharged saleen mustang and another 2005 mustang that a supercharger was added to get some baseline numbers of where the ecu should be at with the supercharger.
Well Here is the next issue.
The car will only run off the stock data that came on the new ecu with some changes.
2. The car will not start on the saleen tune or the other supercharged tune. So I am not sure what is going on here.
I will attach the tune files and the log files for the tunes I was talking about. If someone can help with questions number 1 and 2 I would Appreciate it.
I have attached the following files.
First are the files the car runs off of and the log file named
54 ford stock no pats 2
Attachment 85150
Attachment 85151
Next File is for the Stock Saleen Mustang with supercharger and log file named
54 ford stock no pats 2.1 05SALEEN
Attachment 85152
Attachment 85153
Final file is from a car that a supercharger was added to no log file because the same results happen as the above file no start.
54 ford stock no pats 2.1 1376673627
Attachment 85154
Again any help is much appreciated.
