Thanks. I was thinking the same. Why would it matter, it's all the same MS operating system. I had a high end rugged pc tablet w touch screen and all the same stuff like this machine and it worked fine.
Thanks. I but a support request in
i know this is a new tread but does anyone have the drivers for the old hp tunners pro
It’s on the HPTuners website under downloads.
https://www.hptuners.com/pub/HPT%20F....28%20WHQL.zip
i've tried that link but it doesn't provide the setup but that just installs the software, the only thing posted on the website is for the new MPVI2 they have he software to download that version but on my old pro setup they no longer provide that option here is what it shows on my laptop
Attachment 110865
Those are the drivers. Extract them to a folder somewhere, connect the MPVI, go to device manager, find the device (should have a yellow mark or something similar on it saying it isn’t working correctly), right click and hit update driver or something along those lines. There’s an option for browse my computer or find drivers manually. Point it to the files you extracted originally and that should do it. I’m going from memory but that should be close.
Thanks for the advice but that didn't work at all not sure what the deal is but the right drivers simply won't load onto my new device
I'm having the same issue with my new windows 10 Laptop. Can load the drivers for a MPVI. Device manager says can't find any driver package .INF and I selected the folder with all the drivers.
I did a vcm suite and firmware update on my mpvi 2 today and now when i try to read or write in vcm editor says interface not supported
I tuned my truck 10 mins before and worked fine before updates. VCM scanner still works just editor says interface unsupported.
If I hit VCM info button in editor with hooked to the truck it does show the truck info that way so I know its seeing the mpvi2 it just will not write or read
hi, in 2019 i tune my Camaro 2.0 8 speeds with my MPV1,the MPV1 broke, i have the new MPV2, i read my tune,but in my tune he missed the place to tune the fuel for the highway,at this time i tune to lean it and i cannot yesterday and in my tcm i missed the shift pressure and at each gear??? Can someone help me,sorry for my bad english.I have version 4.10.7 and 2.0828 ...
i recently had uninstalled HPT software, HPT was working fine until I screwed up went to re-install and now i cant get the MPVI to connect. it shows up under the device manager both channels A and B, and has the latest driver. but HPT keeps asking to connect interface..
what next?
i found the directions on page 1 , think i fixed it
