Trying to read tcm off 05 durango 5.7 hemi
when trying to read it fails
i select all dodge controllers and they all fail
i tried ngc4(fail) esgs52 and esg53(fail)
My understanding is that HP Tuners only supports the TCM for the 2007 and later vehicles with the 545RFE. I have a 2005 as well and HP Tuners will not read the TCM.
Also, EGS52/EGS53 is the TCM for the NAG1 units which are not used in the trucks and Durango. The NAG1 is used in Jeeps and LX models and others.
It's tricky , What I've found that works 70 % of the time , is start the vehicle , (with foot on BRAKE @ idle) put it in drive, then in reverse, shut the vehicle off then read, right as it stops reading the PCM , when it tells you that it's waiting 15sec. turn the key off then on, by that time the read function will tell you to cycle the key, do it........you'll know write(see what I did there) away if it's going to work.
I worked for an hour getting this one to read the TCM(see attached...BONE stock 04 1500 Ram GTX I just bought yesterday) , finally on the 6th try it worked.
I've also found that if the vehicle had been previously tuned with a Diablo CMR tune , you have a better chance of it being read, I've read 7 so far that have had a HemiFever Custom tune and all of them the TCM "read" on the 1st try...........and a Superchips tune is a 50/50 1st time read.
Attachment 110752
