P59 ECU NW 102mm DBW help
So tuning on a 2004 Corvette with a mildly built 427. Running a 102 Nick Williams DBW (drive by wire) throttle body. I have the car where it starts up great, idles great and runs amazing at WOT. But every so offer after a good WOT run and immediate release of throttle, the car stalls. What tables is best for helping the stall? I can make it do it in park/neutral and also while driving down the road. But I mean only immediately after going from 100% to 0% commanded throttle. If i more like ease off of the throttle then it will actually come down very nice.
I do get the P0068 & P1516 codes every so often as well. I currently have the Calc Airmass - P1514/P0068 Error table maxed out. What else can I look into on to fix this issue.
I am running a 1 Bar Speed Density Enhanced (RTT) operating system.
The motor was built for boost, so the plans are to finish the turbo system, then get it all installed and go back to tuning. Steve Morris did the motor for me, and told me that I would need to get a standalone system after the turbo system. Do you believe this will be true? The goal is most likely going to be around 1200hp once the turbo system is done. Everything else is completed on the car for it.
Thank you,
