2 Attachment(s)
High idle, only in drive?!
2006 E40, stock everything except the tune file and MAF is deleted. Idle airflow tables are completely untouched. Stock clean throttle body. No vacuum leaks. I have tried the scanner's 'throttle cleaned' and Tech2's 'idle relearn' to no effect, they both seem to do nothing.
This is melting my brain. Idle in park is good, actual RPM is within 30-40 of Idle Desired RPM, Throttle Position and Throttle Desired position are ~2.4% after it stabilizes after startup. Reverse is within 30-40 RPM of desired, Position & Desired are ~4.5%. Neutral same as park. But in drive and only in drive, Throttle Position & Throttle Desired jumps to 8%, with Desired = 552, actual = 725. Back to neutral, reverse, & park it behaves normally. I cannot find anything anywhere in the tune file that would account for this. It's not spark related, something is telling the throttle blade to open, only in drive.
Of course, when driving, coming to a stop it's trying to push through the brakes and engine speed flares at the 2-1 downshift, etc. How do I fix this?
Short log of start, reverse, neutral, DRIVE!!!!!!!!!1, neutral, reverse, park: Attachment 107676
Mess of a tune file: Attachment 107677
