1 Attachment(s)
Engine LLT Stand Alone
Hello ! My name is Mauricio, and i'm from brazil.
I have a LLT Engine, that cames from a Holden Commodore, and i'm trying to use this engine in a project, with manual transmission. So I need to make it works stand alone.
So i bought in USA an E69 ECM, reprogrammed, but they couldn't remove VATS. SO i was looking, and saw that Chevrolet Transverse uses the same engine, but with E39 ECM.
Is it possible, uses E39 ECM on my project ?? E39 Vats can be removed.
Attachment 99470
Thank you !!
you were better off getting an LFX but you still can use the E39 there are some components you need to swap out with LFX such as HPFP, TB, MAF, Harness, and flip injector banks
Mauricio, greetings from a fellow Brazilian. Did you manage to solve your issue with this project? Nice looking prototype.Cheers
