Can anyone point me in the right direction to have decel pops on the 5.7 Hemi eagle engine. I?ve read a few threads about it but no luck. I get very small pops below 1k rpm but above that the car just jerks like crazy
You have too much negative timing in it. Post you tune file.
This guy seems to have a way to do it. Not my cup of tea but should give you an idea of how to do it. Key is negative timing at low RPMs and to disable DFCO apparently.
https://www.youtube.com/watch?v=4M-kaaAiZ40
well the video didn't work. i found a min spark table and changed that, but i'm still get getting decel fuel cut.
and when it does work, the throttle is responding to the change and so it jumps around. on actual decel it makes the car jumpy.
any other ideas?
What is the purpose of this?
besides criticism, does any one have anything constructive to add? something that gets the job done?
What you had for DFCOQuote:
Attachment 99876
What you can try
Attachment 99877
sorry for delay. well, it still doesn't work. didn't have the 19 to test but neighboor had 14 durango rt and i put in homer's values and it worked. you had to pick your cells properly but it worked.
get the 19 and it still has decel fuel cut so doesn't work. the timing goes negative, but there's no fuel.
could it just be a 2019 thing? i didn't check but i think they have the same ecu.
file is same as above, just changes homer suggested.
19's are GPEC2A whereas the 14 durango is a GPEC2
PCM identification
https://forum.hptuners.com/showthrea...tion-2-25-Beta
post your stock file
also try one thing at a time.
only parameter that was different was in enable map, the durango has 2 values, the challenger, just one.
stock file attached.
Attachment 100014
give this a test
hopefully tomorrow.
thanks
