Pids for OBD-II Datalogging (Android) (2011 BMW 135i)
Hi, I am new to the forum. I have been using TrackAddict for a while now to render HPDE and Autocross videos. My problem is, the pids available for logging are lacking. Here is an example of something I rendered recently: https://www.youtube.com/watch?v=QNMAzLZm0OM
Other PIDs I'd like to log:
* Steering Angle
* Actual Pedal Angle instead of "throttle"
* Actual brake switch or line pressure instead of this "calculated brake" which appears to be G-force related...
* Air temp per the outside thermostat instead of the current one being logged which is mounted on the radiator...
* Oil temp?
* Oil pressure?
* ABS cahnnels?
* Wheel speed channels?
The Mevd172 DME in the BMW 135i (N55) has quiet a bit of data that can be logged. I just can't find any apps that can actually poll it... Any help would be appreciated!
Also, I may have the memory addresses for the aforementioned PIDs from my tuner. If I provide that data, could the PIDs be added to trackaddict!?
Other relevant info:
* GS7 Android
* Generic Elm OBD adapter
