Attachment 99227
So my MAF is maxed out at 2700rpm so what to I do now...... 5in and re-scale but I have no idea how to do that!
Attachment 99227
Currently I fitted custom up pipes SXE364.5, 15+ injectors and fuel pump, built gearbox, external wastegate, 4in custom intake and custom hot and cold side pipingAttachment 99237 so far.
Add about 12% to the MAF calculation curve from factory and roll with it.
Would you add 12% to the stock intake or 5in? And why 12% out of interest?
For the 5? To compensate for the now slowed air velocity going across the MAF sensor, since you have changed the diameter of the intake it thinks it has less air.... and 12% because that?s what it takes to bring the MAF back up to about factory air flow.
