Just got a 102 throttle installed can someone guide me how or what to do in tune settings thanks
Is this on your Kubota tractor?
What u mean
What year, make and model of car is this on. Is it stock or do you have modifications. Post your tune. Cable or drive by wire throttle body?
[ATTACH]93002 My bad 07 z06 fast 102 ported intake, 102 throttle dbw, big cam, longtubes, no cats, halltech cai,160 thermo, thank you.
That's a scan---where is the tune? Got a wideband on that setup?
I set it up yesterday works!now i need to figure out how to set it up with tuner, Heres the tune thanks [ATTACH]93039
Go to Engine---Idle---Airflow---ETC Scalar and change to at least 7,300.0000. This works for me, but I have seen some setups as high as 8,000.0000. At least now you know the range. You will have to redo your maf and vve.
changed to 5,200.0000 best so far the rest dont know how to change had this tuner for a week so please understand
Thanks for all the help guys seems nobody wants to help unless you pay them here
The correct value for a 102 is 7355 in newer e38s or e67. On older e38s like yours I would run 6535.
If you have surging on start up you can increase your idle air min tables. This is more for cammed cars, but it may apply to you. You may need to adjust start up air tables as well.
