Is it possible to use a switch I have SCTX4 with customer Tyrant tunes but they want 600$ for tune that will let me they use Ace kind of potentiometer I believe tied into the fuel regulator 2012 6.7 power stroke new to Tuning
The SOTF switch would use the Fuel Temp Sensor as an input. You would then use that to limit torque.
And I can charge between different tunes or make a hot tune and dial it back?
SOTF is one big tune and then torque limit based on "Fuel Temp".
I noticed I have fuel temp modes and altitude I guess depending I can use eighth or and use the 0-5 volt to adjust torque
