PassKey3 Disable
Working on a 2004 Pont Grand AM Se w 2.2L A/T Anyone know for sure if the HP Tuners can successfully disable VTD in this application? I don't want to spend 100 bucks to find it does not work. Over the years I have done many theft disables , but that was with TunerCats software. TC has no support for this application. :doh:
I can only find a sample file for that with a 3.4L, but there the only options are VATS: PWM or Serial. No option for Disable or None.
I helped with a dirt track cavalier with the 2.2 that was like a 2002ish I think. Not sure if they run the same computer as the grand am though. I was able to disable the DTC's for the vats system and it ran no problem. If someone had a stock file I could see if they are the same.
The 3.4L uses a P04, is the Cavalier 2.2 P11 likely to be the same/similar enough? If it is, that one has VATS Enable/Disable controls.
