TCC Slip Questions 8 Speed
I have two questions:
1) TCC desired slip never goes lower than 10 RPM, even though my tables go to zero over 275 Nm. When I am commanding more than 10 RPM I see it go up, just never see it go down.
2) Given the above, I do see it go below 10 RPM but never zero, so I wonder if there just isn't enough pressure to lock it up. This is where I was reading on the regulator offset (20.62 PSI stock) and some say to increase that and some have adjusted the regulator gain (0.360 stock).
Just looking for some feedback on this. It seems like adjusting the offset may increase the pressure to get it to lock better. Just trying to avoid slip when cruising in high gears to *maybe* help fuel economy a little.
