anyone have the transform function for the lm-2 for lambda. getting the 500 something numbers again..
Is the ECM AFM 1500 serial WB setup now on the software now?
I have the same issue with my AEM 30-4100. I am able to read the stream with other software without issue. I was able to read it with previous hp tuners versions. Support was unable to fix it and sent me here.
There should be an option to define the com port and settings since there seem to be issues with the autodetection.
I'm having issues with my LC-2.
Was previously working with no issues at all. I don't log my car on a constant basis.
I hooked my computer up to do a random data log and noticed that my wideband wasn't reading. That was a few days ago.
I've tried reinstalling USB drivers, updated HPTuners, tried a different USB hub, no dice.
I can stream data to logworks with no problems.
I even had readout in logworks AND hptuners at the same time with no problems.
I'm stumped and frustrated. I hate having a functioning scanner configuration that will randomly not work anymore and the reason is not obvious.
I have the same set up I find that the laptop needs to be on and booted into windows then I connect my LC2 via serial-usb then i start the car let the LC2 configure it self and start displaying AFR then I launch HP scanner and it should detect the wideband as long as you have the serial input added in your pid list? Do not run logworks or any other program that uses the serial wideband at the same time as the scanner as only one program can use the serial port so make sure logworks isnt running let me know how this goes for you?
on a side note i dont use the usb 3 ports for the wideband i just use the standard usb 2 ports
ok so i am looking to go serial data with me wide band and my ? is which ones are working properly as an plug and play?? i currantly have and lm1 but it seems as those are still not working that great. was looking at the plx. any suggestions or insight would be great thanks
Does the serial inputs work on standard or just pro?
Yes, operates on both
Ed M
Trying to use a apsx d2 wide band thru serial and it's not on the list, so do I request for it to be added thru support?
At this time, we have no plans to modify any existing serial based sensors or add new ones.
I'm having trouble getting the lm2 set up to scan in hptuners. Does this mean the lm2 cannot be added to scan in hptuners?
I have a Daytona Sensor dual wideband , when i load my voltage value to show lambda , at stoich it s pretty actual , but in WOT , the wideband is at .75 and the log at 1.16 lambda .
At WOT in the run the voltage is climbing to 3.1v instead of around 1.8v . The reading on the dyno is pretty accurate.
I use this (V/7.345)+.68
I have two AEM 30-4110 gauges in my 05 GTO. I previously used the analog input on my MPVI pro, but have recently upgraded to the MPVI2.
Is it possible to log two separate widebands with serial input or are we limited to only one?
I have an LM1 that I used in the previous versions of VCM Scanner that worked fine using the serial interface, I now have the 4.1.206 Beta version and it seems to work but the numbers are reading too high, like the Transform is off somehow. I'm using the LM1 Transform of (V/0.5)+10=Output and it reads about 1-2 points high using the Stoich display. Any ideas what might be causing it, the scanner itself seems to read roughly the same as my AEM Gauge pod, its only the logging that is off... Thanks ahead of time for your help!
