VCM Scanner protocol info
HPT is being slow adding support in VCM Scanner for my vehicle to access the same PIDs that you B8 A4 guys have access to. I'm curious if I modify the protocol settings in my VCM Suite.cfg file if the scanner will be able to access all the extended PIDs that you guys can access. Can someone who has connected VCM Scanner to a B8 A4 please copy and paste their associated <Vehicle> entry from their VCM Suite.cfg for me? You can find the file in Documents\HP Tuners\Settings\VCM Suite.cfg. For example, mine (after removing my VIN) is:
Code:
<Controller ProtocolInfo="4" ProtocolInfo.DiagnosticConnector="1" ProtocolInfo.Bus="10" OBDControllerRoute.ID="7E8" OBDControllerRoute.ControllerType="A" VIN="<removed>" OS="8J0907115BD_0010" ControllerTypeIDByOS="50018" />
