3 Attachment(s)
16 Hellcat Bypass valve bleeding boost???
Attachment 95926
Attachment 95927
Attachment 95928
Hoping to get some experienced eyes on this file.. I have only done a handful of Hellcats and this one is modded the most.. and I believe I have the bypass valve is staying open and then shutting as RPMs increase??? Also only able to get around 6-7 degrees of spark advance at high aircharge loads.. Figured this pulley setup on 93 I could get away with 12
16Hellcat A8 (stock trans file)
220bosch injectors
2.50 pulley/93 octane
Catless H pipe
No mufflers
6" inlet that necks down to factory TB
Makes roughly 18lbs
Thanks for any feedback. If I can help any of you dodge guys on GM ECMs please let me know
