request: clear confirmation of Bluetooth GPS connection
Used a new Garmin GLO2 for the first time this weekend. Also a BT OBD reader that I have successfully used before. Prior to each session I was checking TrackAddict's GPS & OBD indicators, and each time I got green connections to both devices.
Problem is, as I found out afterwards, is that the GPS indicator will turn green even if the BT device is not connected or transmitting, because it falls back to the phone's internal GPS. So some of my TrackAddict sessions were recorded with low-frequency, inaccurate GPS data from the phone instead of the Garmin.
My suggestion is, if the user specifies a Bluetooth GPS device in the settings, do NOT allow the GPS indicator to turn green unless the external device is actively connected (just like the OBD indicator). Thank you.
