1 Attachment(s)
3.5 ecoboost Turbo FMEM / Wastegate airflow limit
My tuning experience is limited to speed density tuning on a not-so-well supported early 2000's jeep PCM. However, tuning and the fundamentals behind it is something I feel I have a good understanding and a healthy respect for engine internals, and the importance of limits.
That being said, I've been messing around with my 2019 F150 3.5 EB. With much searching, reading guides, watching videos, and some experimenting, I've achieved some extra power on my platform. So I'm hitting turbo FMEM as my driver demand limit source, and wastegate airflow as torque max source. I'm not finding a whole lot of clarification on what causes these, and which tables to manipulate to get around it. I don't want to just push unsafe limits either.
My turbo airflow is almost always higher then my turbo desired, so my thoughts are that this condition may be causing the Turbo FMEM, but the air load/desired load seem to be within reasonable difference of each other. The throttle remains open except for shifts, so i assume the wastegates are doing their job regulating boost levels.
I also am doing this on 87 octane. I know its not recommended, but I haven't been touching any of the ignition timing tables with this in mind. The KR isn't pulling tons of timing either, so I think I'm still within reasonable limits.
So I guess what I'm trying to find out is how to gain more from here. Should I be requesting a higher load? Do I need to work around the Turbo FMEM limits?
Any help is appreciated.
Attachment 114276
