This is great news!!
That is pretty slick, I cant wait to play with the tcm on a couple cars.
How deep are you guys going into the BCM? If you could map out the DTC's for the TCM/BCM that would be awesome. You would solve the problem of putting a gen3 with a 580 into restomod stuff. The front wheel speed correlation stuff needs to be shut off to make it all work.
Roger that, I would look at it if I were you guys. The gen3 swap is really gaining momentum and the main trans that came with them is the 580. The cars are 10 years old now and there are lots and lots of these in junkyards waiting to be swapped. Right now there is NO reliable solution for using the 580 in anything other than a stock car.
What are the BCM codes that are being set?
Cant read pcm only tcm
Redownload the software tomorrow morning. Should read fine.
does anyone have a stock file that has the trans tables they would be willing to share? The ones in the repository do not have any trans tables.
hmm strange im not seeing any trans tables. I have version 2.25.2484 too
That file was read wrong, didn't include a read of the TCM in the stock file.
We have read 3 cars with the latest release. Two 2012 and one 2013.
The 2012 did have tweaked TCM modules.
The 2103 Jeep SRT TCM is stock to our knowledge.
In each case the message about outdated TCM calibration comes up.
What gives?
I have encountered the same issue with several TCM's I have read. It appears that a new version of the TCM software is automatically loaded. I believe this note on the first page of this thread indicates this is what will occur:
"Please note that we will not support some outdated EGS53 operating systems (we will update your TCM OS automatically to a newer/supported OS)."
Like Mike pointed out, if you have an unsupported/outdated OS, we will have to update you to a newer/supported OS. If VCM Suite doesn't do this and you still can't access the TCMs, please email support with your .HPT file and VCM Suite Infolog.Quote:
Great Job Bill, HP TUNERS forever:worship:
Newbie question. I just downloaded the new version of Beta sofware to attempt TCM tuning but it will not let me re-read the vehicle. The vehicle is a 2012 Charger SRT-8. What am I doing wrong?
