Transmission>Torque Management>General>"Snub Tqlim Enable" What is it?
I have a 2007 dodge charger for which I am tuning the transmission. The TCM has this parameter called "Snub Tqlim enable = 59mph". Its under torque management so I assume that it either limits some type of torque or sets a speed for limiting to take place. There is no description in the help section and only two references I could find in the forums. Does anyone have a clue what its used for? Does it allow the torque converter clutch, clutches or brakes in the trans to slip to lower torque output of the transmission itself? Does it tell the ecm to lower the torque output of the engine? Anyone have a clue what the Acronym "SNUB" means? Any help Identifying what this is and how it is used will be greatly appreciated:)
