I have an a8 and when I am on the 2 step the throttle is not opening all the way until I get off of brake. Has anyone found a way for the throttle to stay open with foot on the brake?
My very inexperienced thought is you are probably being limited by brake torque. If you post a log and tune I'm sure someone can give you a better answer.
Ok I figured out the throttle part. It goes wot. However there is still that half a second delay before rpms climb. I will post a log.
I just learned how to disable it from having a misfire code. Haven't even looked at the throttle.
Also how do you have yours wired? Just wired to brake pedal or inline switch?
