1 Attachment(s)
Using 2019 L86 ECU on 2017 L83 engine?
Hi there,
I recently purchased a used L83 and T56 to swap into my 280z that was supposed to come with the original ECU. However, after looking at it I noticed it is out of a 2019 6.2 from a cadillac escalade. I went ahead and tried to make it work but I'm having trouble getting things to a driveable state.
I started out by copying most of the tables from a stock L83 tune over except for a few airflow relates ones which I copied from a 2016 camaro as I am using the camaro intake and throttle body. I've since modified a few different tables to try to get things working, but I haven't had much success yet.
From idling the engine and one short drive it seems like the engine hangs at around 1500 rpm on accel and decel and is very slow to decrease in rpms in general. Sometimes the engine will continue to climb in rpms until I shut the car off. The car also seems to buck if I let off the throttle at all.
I hadn't intended to really tune the car any, I'd rather the engine just ran in stock form with a manual transmission and the intake manifold swapped.
I've attached my tune file. Am I going to run into issues trying to make modifications to the 2019 ecu on the 2017 5.3 engine? Or am I missing something else. I feel like I'm missing something important.
Any help appreciated, thanks.
