Oxygen sensor senisitivity/oscillation
Need advice, my OCD is going nuts.
I have longtubes that merge into an X pipe about 24 inches post collectors. I have upstream bungs at collectors, then have downstream bungs about 8 to 12 inches past upstreams.
I have my upstream 02 on passenger side in the downstream spot, because the wideband took its spot. When I turn trims on, it oscillates terribly and does not respond well. The other side is fine.
Can I increase sensitivity on this side, or am I stuck with having another bung welded right next to the wideband? Dont have much room. I want to turn my trims on but cant due to this issue.
Alex
