4 Attachment(s)
C63 Supercharged Timing target/throttle problems
Hello,i did tune this c63 superchaged running 4.5-5 psi .
whenever i change the main timing tables timing drop much lower than the target...if i touched the main or mbt tables timing drops crazy.
so i have used the the maximum durability tables as a timing cap/target.
it worked fine until the customer was complaining of hesitation sometimes on high gear/low rpm hesitation sometimes.
so i tested the car and found it pass the maximum durability tables by 2-4 degrees and its not constant.
and for the throttle i found that the throttle overshoot sometimes and stabilize quickly which causes a slight hesitation...i only cured this by lowering the throttle angle max flow limit @ lower rpms.
my tune and old/new logs attached.
